Release date: January 4, 2022
We released the following updates since 8.32:
Improvements
- Support for using linked fields in calculated field types. Learn more here ! [SG-24633]
- Added the option to download archived event logs from within ShotGrid via the Admin Menu. Learn more here. [SG-24142]
- Email invites now point to the appropriate return-to URL. [SG-22545]
- Added a preference to Security section, which controls Site Administration link visibility for local sites which use SSO log in. [SG-24802]
- Added validation when creating or editing formatting rules: from now, a description and a valid value must be provided. Also added new options, like “is empty”, “is not empty” etc., to check whether the value exists. [SG-23795]
Bug fixes
- API: Fixed an issue where non-admin, non-script users could not update the HumanUser entity. [SG-24626]
- Fixed an issue where using the ‘‘All Playlists’’ filter in Media App was throwing an error. [SG-24405]
- Fixed an issue that prevented data from importing when there was a column named as a pipeline step with pipeline step data [SG-23792]
- Fixed the “Sync user profile with Autodesk Identity” preference in the Site Preference > Advance section, which controls users name synchronization between Autodesk Identity profile and ShotGrid site. [SG-24819]
- Fixed an issue where the native ShotGrid 2fa settings were not visible in Autodesk Identity mode. [SG-24195]
- Removed the “New User Invite Expiry” Preference when in Autodesk Identity mode since the preference didn’t play a role in resetting the password for invites. [SG-24229]
