8.35 Release Notes
Release date: March 1, 2022
We released the following updates since 8.34:
Improvements
:tada: Cross-Project Asset Linking
In production, the ability to reuse Assets has a positive impact on budget and resources—helping teams focus more on creativity rather than rebuilding repetitive components. Assets can now be linked across different Projects in ShotGrid. Whether using a library Project that hosts Assets, or reusing an Asset from any other Project—ShotGrid now supports this functionality!
Learn more about cross-Project Asset linking here.
Other Improvements
  • A valid Email address, as well as First and Last Names (limited to 40 characters), are now required prior to adding a Person. Previously, an error message would appear after adding a Person when these requirements were not met. [SG-25733]
  • When removing a Status from a Project, more information is now presented about the repercussions as well as the option to hide the Status instead. [SG-18333]
Bug fixes
  • Fixed an issue with loading the Trash → File page. [SG-25303]
  • Fixed an issue where users could not edit or create new filters that use the “is_empty” condition on a Thumbnail field. [SG-25308]
  • Fixed an issue with Screening Room and Screening Room for RV not displaying any Versions from a custom Versions page with custom filters applied. [SG-25805]
8.35.0.9690 (Thursday March 3, 2022)
Bug fix:
  • Fixed an issue where increasing the browser window size wouldn’t automatically display other Project navigation Page options that were hidden in a smaller browser size. [SG-25787]
8.35.0.9712 (Monday March 7, 2022)
Improvement:
  • Identity Admin is now able to change name, first name, last name without disabling users. Identity users can change name, first name, last name without disabling users when preference Sync user profile with Autodesk Identity is turned off. [SG-24467]
Bug fix:
  • Fixed an issue when Project Pages menu will become unusable as a part of Other menu after reducing a browser’s windows size [SG-23970]
8.35.0.9725 (Tuesday March 8, 2022)
Bug fixes:
  • Fixed an issue with displaying Assigned To drop-down menu in the filter panel in dark mode. [SG-24671]
  • We are now correctly wrapping very long entity names in thumbnail mode. [SG-18217]
8.35.0.9748 (Thursday March 10, 2022)
Bug fix:
  • Fixed an issue when in some cases a non-admin role couldn’t change a status of an entity. [SG-25794]
8.35.0.9758 (Monday March 14, 2022)
Improvement:
  • Optimize email notification processing time for Inbox emails when many users receive the same Inbox email. For example, notes addressed to many users will take less processing. This will improve email throughput for sites with some email notification usage patterns. [SG-25989]
8.35.0.9789 (Wednesday March 16, 2022)
Improvement:
  • Eliminated some Task change email event traffic. This will increase email throughput for some sites with certain usage patterns. [SG-25990]
Bug fixes:
  • [REVERTED] Fixed an issue where Task Entity type query fields on a Task Template page would display the Task count but would not list them in the detailed pop-up window. [SG-25039]
  • Fixed Replies sorting by chronological order. [SG-24898]
  • Fixed an issue when sending a note via Review Notes App would set the Note Type field value as the default value even when it was created with a different Note Type specified. [SG-21089]
8.35.0.9804 (Monday March 21, 2022)
Bug fixes:
  • Fixed an issue where applying Task Templates was timing out.
  • Fixed an issue where filtering in pop-up dialogues would not work in some cases [SG-26123]
  • Fixed first-time login authentication flow via DCC apps, like RV [SG-25862]
8.35.0.9807 (Tuesday March 22, 2022)
Bug fix:
  • Fixed a regression where users couldn’t update permissions on query fields. [SG-26101]
8.35.0.9841 (Monday March 28, 2022)
Improvement:
  • Improved refreshing on the Task grid’s Start Date, Due Date and Duration fields bulk editing. [SG-26294]
Bug fixes:
  • In Thumbnail View, fixed the Manage Entity Pipeline link option when Pipeline Steps were hidden from a Project. [SG-25776]
  • Fixed session expiry warning visibility in Safari [SG-25616]
