Release date: July 6, 2021
In case you missed it…
We released the following updates since 8.26:
Improvements
A global Department page has been added to the Admin menu to facilitate Department management. [SG-21992]
New
Pipeline Stepfield has been added to theDepartment > Default Layout > Listpage, available to admins. [SG-21992]
Fixed bugs
- Fixed an issue preventing users from connecting to their ShotGrid site. This problem was present on sites using ShotGrid’s native 2FA once their migration to Autodesk Identity had been started. [SG-22882]
- Corrected an issue with API authentication when a ShotGrid site had started their migration to Autodesk Identity [SG-22889]
- When choosing multiple values from a list type field on the filter panel, the page no longer crashes [SG-22741]
- Fixed an issue when a note was created with attachments resulting in attachments not being uploaded and linked to that note. [SG-18604]
- Email notifications now contain download links to all the attached files. [SG-18604]
- Creating a new note no longer creates Change event log entries for attribute values. [SG-23082]
- Overlay Player Cut mode now respects Cut Item in/out values. [SG-22636]
- Fixed an issue where SSO users were unable to log in to an Identity enabled site when Identity security settings require 2FA but not SSO. [SG-23113]
- Fixed an issue where eligible users couldn’t create an active user. [SG-23112]
- Fixed an issue where a license error would often prevent authentication.
