Release date: March 29, 2022
We released the following updates since 8.35:
Improvements
- ShotGrid branding updates.
- Autodesk Identity Admins and Users are now able to change
Name,First Name,Last Namefields without deactivating users when the site preferenceSync user profile with Autodesk Identityis turned off. [SG-24467] - Optimized email notification processing time for Inbox emails when many users receive the same Inbox email. For example, notes addressed to many users will take less processing. This will improve email throughput for sites with some email notification usage patterns. [SG-25989]
- Eliminated some Task change email event traffic. This will increase email throughput for some sites with certain usage patterns. [SG-25990]
- Added new environment variables
TK_SHOTGRID_DEFAULT_LOGINandTK_SHOTGRID_SSO_DOMAINto help in the Autodesk Identity authentication. [SG-24661]
Bug fixes
- Fixed an issue where increasing the browser window size wouldn’t automatically display other Project navigation Page options that were hidden in a smaller browser size. [SG-25787]
- Fixed an issue when Project Pages menu became unusable as a part of
Othermenu after reducing a browser’s windows size [SG-23970] - Fixed an issue with displaying the
Assigned Todrop-down menu in the filter panel in dark mode. [SG-24671] - We are now correctly wrapping very long entity names in thumbnail mode. [SG-18217]
- Fixed an issue when in some cases a non-admin role couldn’t change a status of an entity. [SG-25794]
- Fixed Replies sorting by chronological order. [SG-24898]
- Fixed an issue when sending a note via Review Notes App would set the Note Type field value as the default value even when it was created with a different Note Type specified. [SG-21089]
- Fixed an issue where applying Task Templates was timing out.
- Fixed an issue where filtering in pop-up dialogues would not work in some cases [SG-26123]
- Fixed the first-time login authentication flow via DCC apps, like RV [SG-25862]
- Fixed a regression where users couldn’t update permissions on query fields. [SG-26101]
