I have a problem logging into the Shotgrid desktop app. When I click “Sign In” button I get redirected to Web Login page, it is blank though. Strangely, the same happens with Maya, difference is that I can still interact with maya (ctrl s and ctrl o works and after opening a file it is working correctly). I tried just typing the credentials but no luck. I have seen similar issue here but the workaround was for MacOS, how can I fix this in Linux?
Hello vandam!
Recently I found my self figthing with the same issuse on fedora 36, and after reading some of the responses for mac here on the forum and doing a little bit of googling i found a fix!.
I open Shotgrid Desktop from console like this:
/opt/Shotgun/Shotgun
so, before that, just run this command:
export QTWEBENGINE_CHROMIUM_FLAGS="--no-sandbox"
and thats it, the login window will show up the login page.
hope it works.
