Our systems team is running into a spot of trouble getting RV to detect the AJA Kona4 card. They’ve confirmed the drivers are properly installed per the AJA docs.
Version 7.3.2, built on May 17 2019 at 08:30:05 (HEAD=d5d93d93c). (L)
Copyright (c) 2017 Autodesk, Inc. All rights reserved.ERROR: Cannot open: Driver version 0 older than SDK version 14
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
INFO: loaded shotgun config module ‘shotgun_fields_config_standard’ (/opt/rv-Linux-x86-64-7.3.2/plugins/Mu/shotgun_fields_config_standard.mu)
AJA: AJA: no devices found
INFO: BlackMagic-SDI: Decklink driver failed to initialize or is not installed
Before we escalate to an official support ticket, anything obvious we might be missing here?
