RV to Aja Kona 4 Issues
Hello, I’m trying to connect RV to a barco projector in dual SDI with an AJA Kona video card. I’ve been using Assimilate Scratch until now which is working fine with the card, but no luck setting in correctly in RV, I have no image when I set the video settings the same way as Scratch, drivers are updated. I’m in 2k 24p with 2 SDI input and 2 SDI output. Below you can see the settings of the three.
konasettings
Does anyone have an idea what I set wrong? I tried different settings on RV but nothing seems to be working.
Thank you
Hi, It`s been a while since u posted but, i have familiar issue. Have u solved the problem? thanx
I did manage to find a settings that worked but it is still wrong compared to how it is supposed to work. i have to set it to UHD quad in 3D and it works. Even though I am not in 3d or 4k it’s the only settings that worked correctly.
