Release Date: July 16th, 2025
Download available here .
This patch release of RV 2024.2.1 introduces some enhancements to the Live Review feature and addresses critical issues.
Improvements
- Added an option to set the Player’s audio output to ‘Mute’ by default when participants join a Live Review session. [SG-39187]
- Added timecode information to the metadata of image sequences that are submitted to FPT via RV’s Submit Tool. [SG-38366]
Bug Fixes
- Fixed an issue where incorrect start frame was set when loading movie files due to the FFmpeg 6.1.2 update in RV 2024.2.0. [SG-37903]
- Fixed an issue in the Nuke integration package in RV that prevented it from working with Nuke 13/14/15. [SG-32963]
- Fixed an issue in loading URLs from command line if
setServerURLValue(url)command is set without a scheme (i.e: https://). [SG-38734] - Fixed intermittent errors when launching RV 2024.1.0 and 2024.2.0 on Rocky 9.4. [SG-38409]
- Fixed an issue that would freeze the application when using OCIO SYNDisplay/SYNLinearize nodes. [SG-37901]
- Fixed a regression that prevented the
rvNetwork.pyfile from being present after installing the application. [SG-38104] - Fixed a regression that prevented the
rvSession.pyfile from being present after installing the application. [SG-38030] - Fixed a regression where RV could not load the media of a session file after authentication if the session was opened via command line. [SG-37909]
- Fixed a crash on Windows when enabling Presentation Mode with the AJA SDK. [SG-37815]
- Fixed an issue with the timecode option not working anymore when doing operations with RVIO via command-line. [SG-38274]
- Fixed a login issue with the App Session Launcher by making it use
SHOTGUN_API_CACERTSsimilar to python-api. [SG-38301] - Fixed an issue with degraded CPU performance in the RV cache process for PNG video encoded media. [SG-37933]
- Fixed an issue with the ‘w’ keyboard shortcut so it now fits the window to the image. [SG-38144]
