I’ve just started updating from 2022.0.0 to 3.1. so I skipped the Multiple Media Representation Feature launch last release.
Multiple Media Representation feature is now working as expected when using RV with Python 2 or Python 3. [SG-28116]
I would expect the feature to still be working, when I want to watch an already loaded source, but it doesn’t. When returning to a cached sourceGroup the different sources for Frames, Movie and Streaming are not available in the sources Menu and the bottom menu states Streaming, but the Frames are loaded. If I then want to use the ShotGrid Menu like before, I get this ErrorMessage:
ERROR: Could not Swap Media: exception: “in commands.setActiveSourceMediaRep: Can’t find switch node associated with source node sourceGroup000000_source to select the ‘Streaming’ media representation.”
I have a clean working area, to make sure none of my adaptations are causing this error. So do you think this needs a new Error Report or is there a QuickFix I am missing?
Cheers, Henna
