Release Date: May 9, 2023
Download available here.
You can now download RV 2022.3.2, an update to RV 2022 that improves stability. This update also includes the following bug fixes:
- Fixed an intermittent issue in RV where no audio plays the first time RV is opened or playback is started. [SG-28578]
- Fixed an issue where the audio doesn’t play when launching RV through python commands in a terminal when the Audio Cache option is active (
Scrubbing On By Default (Cache All Audio)). [SG-29287] - Fixed the missing redraw when using the
setMargins()RV command. [SG-28734] - Fixed some intermittent crashes in RV when working with large images and the
RV_SOURCE_TILINGenvironment variable is active. [SG-28211]
