We are customizing the booking entity for financial previsions. We use the booking that are created in the crew planing, we compute a duration field and we would like to add a cost field with multiplies people daily cost with duration.
This cost field need to be restricted for managers only. Is it possible? I can’t find any booking settings like for other entities.
Kevin
Hi Kevin!
You can manage field visibility on Bookings just like any other entity. First navigate to your Permissions page, twiddle open the permission group you want to edit > Field Permissions > Booking:
From there you can toggle on/off visibility and edit permissions for each field. Hope that does the trick for you!
Thank you very much.
I was searching for this under “Site preferences > Entities”
