Play button not working
Hope you are doing well. I was wondering if anyone can guide me on this problem.
Whenever I try to hit play it says playing on the title bar but it wont actually play anything everything seems to work when I scrub the timeline. Just the play bar wont work there are no errors or warnings in the log.
INFO: loaded shotgun config module 'shotgun_fields_config_standard' (D:/Program Files/Shotgun/RV-7.8.0/plugins/Mu/shotgun_fields_config_standard.mu)
INFO: using shotgun server 'https://bouldermedia.shotgunstudio.com'
INFO: C:/Users/MANISH MALVI/OneDrive - Hasbro Inc/rvRenders/sq0225.mov
Hi Manish,
That is very strange, do you know what FPS it says in the bottom-right of the window?
-Kessler
@Michael.Kessler
It is still playing at 0 fps and my default preferences is set to 24 fps.
It worked when I used a regular set of headphones instead of the USB ones.
