Launching RV 7.5.1 on mac (not RV64)
I have a playlist I want to review on my mac but when I ‘Play in RV’ it launches RV64. How do I get it to use my newly installed ‘RV’? I can’t see any entries for this on the software page.
Many thanks, Michael
Hi Michael,
Welcome to Community @ Shotgun
From the command line, navigate to the installed location and run the following command:
./RV -registerHandler
This command will register the current binary has the default handler for “Play in RV”.
Hope this fix your issue.
Regards,
Alain
Great - thank you Alain.
That fixed it but now my playlist won’t launch - I’m getting the spinning wheel so I can’t tell what the errors are. Should I open a ticket?
Michael
Hi Michael,
Thank you for using community!
There are a couple of things you can check first before opening up a ticket with us:
  • What version of Shotgun are you using and what browser?
  • Do you have Screening Room or Shotgun Review enabled?
Alexa
Hi Alexa - it’s launching fine from the website - it’s just locking up once it’s loaded my playlist as a timeline. I’m using shotgun review
Hey Michael,
Are you using a custom version of Toolkit by chance?
Also have you tried cleaning out the Shotgun Toolkit cache to see if it helps? (Example: Windows: C:\Program Files\Shotgun\, Mac: Library/Application\ Support/Shotgun).
