RV not launching from Shotgun anymore
Greetings again,
I have recently upgraded to Mac 0S 10.15.5 Catalina. Now RV 7.7.1 will not launch from SG anymore.
If I have RV open it will work, but it will not launch RV anymore if it is currently not open.
Daniel
Hi Daniel,
Can you try running RV from the command-line with -registerHandler to try to re-register the handler?
To do this, go to your terminal and run:
/Applications/RV.app/Contents/MacOS/RV -registerHandler
Once you do that, does it reassociate it with the rvlink protocol?
-Kessler
I was so hoping that was it.
Same. It bounces once in the Dock then nothing.
Daniel
Can you check the console app and see if there are any cash logs unde User Reports around the times you are trying?
I am lost in the new Catalina console…
Aug 14 10:57:24 wb-animation-f5kd20fbk7gf Google Chrome[5656]: BUG in libdispatch: 19F101 - 274 - 0xf
Aug 14 10:57:24 wb-animation-f5kd20fbk7gf com.apple.xpc.launchd[1] (com.tweaksoftware.RV.3600[36215]): Service exited with abnormal code: 1
Aug 14 10:58:02 wb-animation-f5kd20fbk7gf com.apple.xpc.launchd[1] (com.apple.mdworker.shared.0F000000-0300-0000-0000-000000000000[36205]): Service exited due to SIGKILL | sent by mds[133]
That’s strange, so it bounces once when you launch from Shotgun, but not when launching interactively?
It launches from the dock fine.
When I launch from SG without a current RV session open it bounces once then nothing.
When I have it open it usually works, just opens in the fresh RV session.
If I only have an empty RV session open it seems to always work.
Lots of times it wont load when I have a current RV session open. THrows a bunch of errors in the RV console. Seems like the contexts between the 2 RV session are not playing nice.
My session IS validated with our server.
ERROR: Toolkit initialization failed. Please authenticate RV with your Shotgun server and restart.
File “/Applications/RV.app/Contents/PlugIns/Python/sgtk_bootstrap.py”, line 308, in initialize_toolkit
mgr.bootstrap_engine(“tk-rv”)
File “/Users/deaton/Library/Caches/Shotgun/wba/site.rv_review/cfg/install/core/python/tank/bootstrap/manager.py”, line 481, in bootstrap_engine
engine = self._start_engine(tk, engine_name, entity)
File “/Users/deaton/Library/Caches/Shotgun/wba/site.rv_review/cfg/install/core/python/tank/bootstrap/manager.py”, line 1155, in _start_engine
engine = tank.platform.start_engine(engine_name, tk, ctx)
File “/Users/deaton/Library/Caches/Shotgun/wba/site.rv_review/cfg/install/core/python/tank/platform/engine.py”, line 2811, in start_engine
return _start_engine(engine_name, tk, None, context)
File “/Users/deaton/Library/Caches/Shotgun/wba/site.rv_review/cfg/install/core/python/tank/platform/engine.py”, line 2936, in _start_engine
“tank.platform.current_engine().destroy().” % current_engine())
TankError: An engine () is already running! Before you can start a new engine, please shut down the previous one using the command tank.platform.current_engine().destroy().
INFO: Queued events waited 0.287109 seconds.
INFO: Processing event ‘external-gma-play-entity’ 0.305664 seconds after startup.
