Low Hanging Fruit
Somewhere on LinkedIn, I saw that Autodesk was looking for a Production Scheduling Expert to interface with users and report back on ideas for how to make Shotgrid/Flow a better tool for production tracking and scheduling. Let’s help 'em out! What, in your opinion, are the simplest, most easy-to implement things that would make your user experience better? I’m particularly asking production managers. (NOT coders/developers). Whenever the answer is “just write a custom script,” I want to sue Autodesk for mental pain and suffering. Our development team is BUSY. They are EXPENSIVE. I’m looking for the things that a production manager should be able to do through the user interface and basic functionality, without needing to run to a developer.
Here are the top 3 things Shotgrid/Flow could do to make my life easier:
  • Custom roll ups (as described here: Give status percentage summary by exclude omit). Ability for dependencies to ignore certain statuses. (for example, if a task is omitted, it’s dependency should be ignored)
  • Filter & Report using query fields.
  • Better UI for status dependency setup and tracking (ability to draw dependencies on the Gantt chart rather than right-clicking; having a Gantt chart for the task template so that we can set up the dependencies visually at the time we create the template, etc).
Production Managers: What are your top 3?
Of these, we already scripted our own solutions for the second two. (but would have been great if we didn’t have to). The first one we don’t have a scripted solution for yet (doing so caused issues with unintentionally triggering pinned tasks)
  1. We need to be able to use the task templates to schedule in gaps (a task starts 5 days after the previous dependent task) and without creating fake “downtime” tasks.
  2. Also, something we developed into and were surpised wasn’t an expected use case… using task templates “a-la-cart” where you can apply multiple templates based on specific use cases (having one template to add all common tasks, and then adding a template of FX tasks only to scenes that will need them). We already have custom scripts to make this work well, but you’d have some bugs if you tried to do this without the extra work-arounds.
  3. Displaying a view where rows can be entities and columns can be tasks (but doesn’t require you to show ALL tasks in a given pipeline step).
Isn’t 2 already possible?
Its been improved recently and allows you to merge tasks from other Task Templates on top of your existing tasks.
Hi @pen
Not sure if this is what your meaning but thought I’d chime in on a couple of your items.
omitted tasks/dependency ignoring - If you set your omitted tasks to Milestones they become points in time instead of holding a duration which effectively mutes them in the dependency tree without breaking it.
Drawing dependencies - If you give your tasks start/due/duration data, even if its for a template, so they appear in the gantt view, you can hold down ALT/Option on your keyboard and you’ll get a small circle on either side of each task as you hover over them. You can click/drag those to other tasks as dependency links. If you don’t want your template to hold dates/durations you can just clear those after your linking is done.
On a side note, if you hold ALT/Option and click/drag the tasks bar in the gantt while a dependency exists you will introduce a dependency offset (you’ll see the dependency arrow turn blue).
Since we are making a lists of scheduling related requests, I’d really like the split task function to be ironed out more so that it works with some of the related tools like the resourcing app.
Also task dependency offsets could use some additional controls in the site. Maybe an exposed connection entity could work but just the ability to set some general rules for each connection would be helpful directly in the site instead of just in the API. Even if it’s purely reporting related so that those rules could be visible in the site would be helpful.
  • Timelog Missing Report and Maybe Timelog Missing Notifications to the artists
  • For Gaming, Scheduling isn’t a issue but Reviewing is Proper Reviewing tools within the web browser itself would work
  • Similar to the button ‘Add Note to selected’ , There could be an option for ‘Add Version to the selected task’.
  • Bulk Upload of Thumbnails
You can bulk upload thumbnails with the new import tool.
This is an interesting idea. We definately wouldn’t want the dates to populate with the tasks, but it does give some method for embedding those offsets. (I do wish it could be clearer and more transparent to users). I’ll play around with it. Thanks @PeteHart.
@Ricardo_Musch my #2 is sort of possible… we’ve been doing it for years and having a script trigger the additional task templates. We ran into a bug at the beginning of this year where we realized it behaved differently if a human changed the task template field. When the script made the change, the existing tasks still remembered which task template they originated from… so if you switched it back, the tasks would match up and not be duplicated. However, if a Human edited the task template field, the tasks that you choose to keep from the previous template would loose their task template connection, and if the task tempalte field was changed back those tasks would get duplicated. I opened a case with Autodesk and they seemed surprised that we would work with task templates in this way. I didn’t get the sense that they were planning any code updates to address this. We “solved” it on our end… if a task’s template field is ever cleared out, we use an event plugin to explicitly reset it for us.
