Give status percentage summary by exclude omit
Hi there,
Sometimes in production, we might create tasks with task template which may create tasks more than we need (but we might need them later) and to do the summary if it’s possible to exclude some statuses such as omit It could be better for us able to see the overview of all processes
or you have any suggestion, please let me know
Create custom pages with filters to show what you need?
Or create query fields on the linked entity schema for those tasks that does the summary percentage excluding status-omit tasks.
I agree with this request. It would be great to have the option to preset the filter parameters on the shotgrid defaults. Yes, you can create custom query fields, but it’s a lot of fussy work if you are doing custom query fields to roll up the status on each pipeline step. Shotgrid already has the pipeline rollups built in, so it’s frustrating to reinvent the wheel just so that you can get a summary that excludes omitted tasks.
I totally agree, pen… been asking for Pipeline Step custom controls for a decade.
Sometimes clients ask us to stop working on specific things that get later abandoned. “In Progress” tasks will be set to “Omit” when this occurs. Those “Omit” tasks cannot simply be deleted to get around the summary issue; we need to keep track of timelogs on the task prior to it being set to Omit.
This feature is a requirement.
I have a similar situation. Sometimes a task on an asset or shot is no longer required, but we need to keep track of it for auditing purposes.
I initially created a new status in the list named Retired. But, as other’s have noted, this still counted against the status percentage. It seems, with any entry in this field it will be counted as an active task.
My only resolution that works for us is to delete the status name in the field leaving it blank. This way the entry is not factored in to the status percentage. I was hoping to find another solution, but this works for now.
It would be great to have custom “Status Groups” that drive these summaries, similar to the configuration that was possible with Shotgrid Create.
