When we review a playlist with versions from multiple sequences we have an issue seeing all of them in the cut.
What happens is that the first version we open the CutTray with in RV will load the cuts for that sequence. Then for the remainder of the RV session only the cuts for that sequence are available in the CutTray even if we click on the CutTray on a version from another sequence. This makes it impossible to review versions from different sequences in one session.
The behavior we want is that the CutTray automatically loads another cut sequence when required.
Has anybody else run into the same problem? Found a solution? Thanks!!!
