When I’m viewing a cut in SG there is an option to select “View in Screening Room (for RV)”. However when I select either of those options the cut never loads into screening room and I can’t search for it either. Is this functionality actually possible? If so, could someone explain what I’m doing wrong to be able to achieve this. At the moment in screening room I’m only able to see playlists and not cuts.
Edit:
Also just wanted to mention that the “Play in RV” button is greyed out so I also can’t select that.
Mitchell
