disappeared notes
Uploading: 1.jpg…
Uploading: 2.jpg…
The notes have disappeared from the task. And I see that they are, but they are not displayed in the activity. This is a selective problem. Everything is fine in the network task of this task. This is not the first time this has happened. Creating a new task usually sucked, but now there are a lot of such passes and there is no way to stop them from memory
Look at the history of the Note or Task to see what/who is making the changes
I understood what was the problem. some users were written in Latin. and therefore in the table Created by they are empty. Unfortunately, as an administrator, I cannot edit this field. How can I quickly solve this problem without downloading these notes again?
Is it their names?
They would have edit that in Autodesk Identity login, then logout and relogin to shotgrid, this will pull the updated name from Autodesk Identity to ShotGrid.
