Tk-multi-publish2 show based setting
What is the best way to handle show-based settings for tk-multi-publish2? For example, show A and show B use the default publish workflow while show C and has their own custom publish workflow?
It looks like with the current setup, I will need to create a different configuration for each show rather than maintain one configuration for all shows and allow different settings/template for each show.
Iris
Hi Iris
That is correct, the normal approach would be to have a different config.
However it is possible to do a per project configuration in the same config, but it becomes more complicated. I suggest an approach here:
Best
Phil
Thank you, Phil. I read the post and it was really helpful!
