ShotGrid menu operations crash Houdini
I am running Houdini Indie 18.5.499. I tried upgrading pipeline to latest core and tk-houdini with dependencies but see no improvement. I cannot file open or save. Do you have suggestions? I think it might have issues with Qt? These are the last three lines in the tk-houdini.log:
2022-02-08 14:06:17,580 [19709 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] Retrieving current scene path…
2022-02-08 14:06:17,580 [19709 DEBUG sgtk.core.platform.bundle] <Sgtk App 0x16b501910: tk-multi-workfiles2, engine: <Sgtk Engine 0x16b3cf190: tk-houdini, env: project>>: Resolved hook expression (associated with setting ‘hook_scene_operation’): ‘{self}/scene_operation_tk-houdini.py’ → [’/Volumes/R4i/Shotgun/configs/the_ferry/install/app_store/tk-multi-workfiles2/v0.13.1/hooks/scene_operation_tk-houdini.py’]
2022-02-08 14:06:17,581 [19709 DEBUG sgtk.env.project.tk-houdini] Detected std style sheet file ‘/Volumes/R4i/Shotgun/configs/the_ferry/install/app_store/tk-multi-workfiles2/v0.13.1/style.qss’ - applying to widget <tank.platform.qt.tankqdialog.FileOpenForm_TkWidgetWrapper object at 0x18ee5f0e0>
The error might not be in the last lines. I guess upload the whole file.
I upgraded Houdini to 18.5.759. I cleared the Shotgun cache. Here is a complete tk-houdini.log sanitized for usernames, etc. in two parts: this is part 1 of 2. The actions I took for this are: I launched Houdini from Shotgun Desktop and selected File Save from the ShotGrid menu in Houdini. Thanks for the help.
2022-02-08 17:14:47,187 [62427 DEBUG sgtk.core.log] Writing to standard log file /Users/@USERNAME@/Library/Logs/Shotgun/tk-houdini.log
2022-02-08 17:14:47,195 [62427 DEBUG sgtk.core.platform.environment] Loading environment data from path: /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/config/env/project.yml
2022-02-08 17:14:47,949 [62427 DEBUG sgtk.core.log] Debug logging enabled. To permanently enable it, set the TK_DEBUG environment variable.
2022-02-08 17:14:47,949 [62427 DEBUG sgtk.core.log] Setting TK_DEBUG in the environment for this session. This ensures that subprocesses spawned from this process will inherit the global debug logging setting from this process.
2022-02-08 17:14:47,949 [62427 DEBUG sgtk.env.project.tk-houdini] Detected setting ‘config/env/project.yml:tk-houdini.debug_logging: true’ in your environment configuration. Turning on debug output.
2022-02-08 17:14:47,950 [62427 DEBUG sgtk.env.project.tk-houdini] Engine init: Instantiating <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>
2022-02-08 17:14:47,950 [62427 DEBUG sgtk.env.project.tk-houdini] Engine init: Current Context: Project @PROJECTNAME@
2022-02-08 17:14:47,950 [62427 DEBUG sgtk.env.project.tk-houdini] <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>: Initializing…
2022-02-08 17:14:47,950 [62427 DEBUG sgtk.core.util.qt_importer] Requesting Qt4-like interface
2022-02-08 17:14:47,951 [62427 DEBUG sgtk.core.util.qt_importer] Unable to import module ‘QtWebKit’: No module named ‘PySide2.QtWebKitWidgets’
2022-02-08 17:14:47,951 [62427 DEBUG sgtk.core.util.qt_importer] Unable to import module ‘QtWebEngineWidgets’: module ‘PySide2.QtWebEngineWidgets’ has no attribute ‘QtWebEngineWidgets’
2022-02-08 17:14:47,951 [62427 DEBUG sgtk.core.util.qt_importer] Imported PySide2 as PySide.
2022-02-08 17:14:47,951 [62427 DEBUG sgtk.core.util.qt_importer] Requesting Qt5-like interface
2022-02-08 17:14:48,257 [62427 DEBUG sgtk.core.util.qt_importer] Imported PySide2.
2022-02-08 17:14:48,260 [62427 DEBUG sgtk.env.project.tk-houdini] Loaded font file into memory: /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/core/python/tank/platform/qt/fonts/OpenSans/OpenSans-Regular.ttf
2022-02-08 17:14:48,262 [62427 DEBUG sgtk.env.project.tk-houdini] Loaded font file into memory: /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/core/python/tank/platform/qt/fonts/OpenSans/OpenSans-Light.ttf
2022-02-08 17:14:48,263 [62427 DEBUG sgtk.env.project.tk-houdini] Loaded font file into memory: /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/core/python/tank/platform/qt/fonts/OpenSans/OpenSans-Italic.ttf
2022-02-08 17:14:48,264 [62427 DEBUG sgtk.env.project.tk-houdini] Loaded font file into memory: /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/core/python/tank/platform/qt/fonts/OpenSans/OpenSans-CondLight.ttf
2022-02-08 17:14:48,266 [62427 DEBUG sgtk.env.project.tk-houdini] Loaded font file into memory: /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/core/python/tank/platform/qt/fonts/OpenSans/OpenSans-Bold.ttf
2022-02-08 17:14:48,266 [62427 DEBUG sgtk.env.project.tk-houdini] Importing python modules in /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-houdini/v1.8.2/python…
2022-02-08 17:14:48,283 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-about] App init: Instantiating <Sgtk App 0x16f94bf90: tk-multi-about, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,283 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-widget_v1.x.x as tk-framework-widget in <Sgtk App 0x16f94bf90: tk-multi-about, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,293 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-qtwidgets_v2.x.x as tk-framework-qtwidgets in <Sgtk Framework 0x16f80ce90: tk-framework-widget, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,300 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-shotgunutils_v5.x.x as tk-framework-shotgunutils in <Sgtk Framework 0x16f94bfd0: tk-framework-qtwidgets, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,309 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] <Sgtk Framework 0x16f7f85d0: tk-framework-shotgunutils, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>: Initializing…
2022-02-08 17:14:48,310 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Posting old cached data clean up…
2022-02-08 17:14:48,310 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Cleaning all files with a modification date older than 2021-12-10 17:14:48.310163 under locations /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg, /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg_nav, /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/thumbs, /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/multi_context, /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/p123c1/fw-shotgunutils/sg, /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/p123c1/fw-shotgunutils/sg_nav, /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/p123c1/fw-shotgunutils/thumbs, /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/p123c1/fw-shotgunutils/multi_context
2022-02-08 17:14:48,311 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-qtwidgets] <Sgtk Framework 0x16f94bfd0: tk-framework-qtwidgets, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>: Initializing…
2022-02-08 17:14:48,311 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-shotgunutils_v5.x.x as tk-framework-shotgunutils in <Sgtk Framework 0x16f80ce90: tk-framework-widget, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,311 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-widget] <Sgtk Framework 0x16f80ce90: tk-framework-widget, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>: Initializing…
2022-02-08 17:14:48,311 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-about] Importing python modules in /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-about/v0.4.1/python…
2022-02-08 17:14:48,312 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘Work Area Info…’ with options:
{‘app’: <Sgtk App 0x16f94bf90: tk-multi-about, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>,
‘description’: 'Shows a breakdown of your current environment and ’
‘configuration.’,
‘icon’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-about/v0.4.1/icon_256.png’,
‘prefix’: None,
‘short_name’: ‘work_area_info’,
‘type’: ‘context_menu’}
2022-02-08 17:14:48,324 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-screeningroom] App init: Instantiating <Sgtk App 0x16e551e10: tk-multi-screeningroom, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,325 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘Jump to Screening Room in RV’ with options:
{‘app’: <Sgtk App 0x16e551e10: tk-multi-screeningroom, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>,
‘description’: ‘Screening Room integration right inside your application.’,
‘icon’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-screeningroom/v0.5.1/icon_256.png’,
‘prefix’: None,
‘short_name’: ‘screening_room_rv’,
‘shotgun_multi_select_action’: True,
2022-02-08 17:14:48,325 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘Jump to Screening Room Web Player’ with options:
‘prefix’: None,
‘short_name’: ‘screening_room_web’,
2022-02-08 17:14:48,351 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-shotgunpanel] App init: Instantiating <Sgtk App 0x16f976310: tk-multi-shotgunpanel, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,351 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-shotgunutils_v5.x.x as tk-framework-shotgunutils in <Sgtk App 0x16f976310: tk-multi-shotgunpanel, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,351 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-qtwidgets_v2.x.x as tk-framework-qtwidgets in <Sgtk App 0x16f976310: tk-multi-shotgunpanel, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,351 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-shotgunpanel] Importing python modules in /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-shotgunpanel/v1.8.1/python…
2022-02-08 17:14:48,358 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-qtwidgets] Importing python modules in /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-framework-qtwidgets/v2.10.2/python…
2022-02-08 17:14:48,360 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Importing python modules in /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-framework-shotgunutils/v5.8.4/python…
2022-02-08 17:14:48,670 [62427 DEBUG sgtk.env.project.tk-houdini] Registered panel tk_multi_shotgunpanel_main
2022-02-08 17:14:48,671 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘ShotGrid Panel…’ with options:
{‘app’: <Sgtk App 0x16f976310: tk-multi-shotgunpanel, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>,
‘description’: 'Panel UI with ShotGrid information about your scene, yourself ’
‘and the things around you.’,
‘icon’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-shotgunpanel/v1.8.1/icon_256.png’,
‘icons’: {‘dark’: {‘png’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-shotgunpanel/v1.8.1/resources/shotgun_panel_menu_icon.png’}},
‘prefix’: None,
‘short_name’: ‘shotgun_panel’,
‘type’: ‘panel’}
2022-02-08 17:14:48,707 [62427 DEBUG sgtk.core.platform.validation] The ‘{engine_name}’ token found in ‘hook_scene_operation’ hook value: {self}/scene_operation_{engine_name}.py. No engine currently running. Skipping validation.
2022-02-08 17:14:48,708 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] App init: Instantiating <Sgtk App 0x15e8d7d10: tk-multi-workfiles2, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,709 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-shotgunutils_v5.x.x as tk-framework-shotgunutils in <Sgtk App 0x15e8d7d10: tk-multi-workfiles2, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,709 [62427 DEBUG sgtk.env.project.tk-houdini] Registering instance tk-framework-qtwidgets_v2.x.x as tk-framework-qtwidgets in <Sgtk App 0x15e8d7d10: tk-multi-workfiles2, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>
2022-02-08 17:14:48,709 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] Importing python modules in /Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-workfiles2/v0.13.1/python…
2022-02-08 17:14:48,732 [62427 DEBUG sgtk.core.util.shotgun.connection] Creating SG connection from <SessionUser @USERNAME@@@STUDIODNS@ @ https://@SITENAME@.shotgunstudio.com>…
2022-02-08 17:14:48,733 [62427 DEBUG sgtk.stopwatch.tank.util.shotgun.connection] create_sg_connection: 0.000304s
2022-02-08 17:14:49,041 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘File Open…’ with options:
{‘app’: <Sgtk App 0x15e8d7d10: tk-multi-workfiles2, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>,
‘description’: 'Using this app you can browse, open and save your Work Files ’
‘and Publishes.’,
‘icon’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-workfiles2/v0.13.1/icon_256.png’,
‘icons’: {‘dark’: {‘png’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-workfiles2/v0.13.1/resources/file_open_menu_icon.png’}},
‘prefix’: None,
‘short_name’: ‘file_open’}
2022-02-08 17:14:49,041 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘File Save…’ with options:
‘and Publishes.’,
‘icons’: {‘dark’: {‘png’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-workfiles2/v0.13.1/resources/file_save_menu_icon.png’}},
‘prefix’: None,
‘short_name’: ‘file_save’}
2022-02-08 17:14:49,042 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘Toggle Debug Logging’ with options:
{‘description’: 'Toggles toolkit debug logging on and off. This affects all ’
'debug logging, including log files that are being written to ’
‘disk.’,
‘icon’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/core/python/tank/platform/qt/book_256.png’,
‘prefix’: None,
‘short_name’: ‘toggle_debug’,
2022-02-08 17:14:49,042 [62427 DEBUG sgtk.env.project.tk-houdini] Registering command ‘Open Log Folder’ with options:
{‘description’: ‘Opens the folder where log files are being stored.’,
‘icon’: ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/core/python/tank/platform/qt/folder_256.png’,
‘prefix’: None,
‘short_name’: ‘open_log_folder’,
2022-02-08 17:14:49,047 [62427 DEBUG sgtk.env.project.tk-houdini] Constructing dynamic SG menu.
2022-02-08 17:14:49,049 [62427 DEBUG sgtk.env.project.tk-houdini] Dynamic menu written to: /@TEMPDIR@/T/tk-houdiniNG5CCJ/MainMenuCommon.xml
2022-02-08 17:14:49,338 [62427 DEBUG sgtk.env.project.tk-houdini] Creating new shelf: ShotGrid
2022-02-08 17:14:49,340 [62427 DEBUG sgtk.env.project.tk-houdini] Grouped registered commands.
2022-02-08 17:14:49,340 [62427 DEBUG sgtk.env.project.tk-houdini] Creating context menu…
2022-02-08 17:14:49,340 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: Jump to ShotGrid
2022-02-08 17:14:49,341 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: Jump to File System
2022-02-08 17:14:49,342 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: Work Area Info…
2022-02-08 17:14:49,343 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: Jump to Screening Room in RV
2022-02-08 17:14:49,344 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: Jump to Screening Room Web Player
2022-02-08 17:14:49,345 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: Toggle Debug Logging
2022-02-08 17:14:49,347 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: Open Log Folder
2022-02-08 17:14:49,348 [62427 DEBUG sgtk.env.project.tk-houdini] Creating favourites…
2022-02-08 17:14:49,348 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: File Open…
2022-02-08 17:14:49,349 [62427 DEBUG sgtk.env.project.tk-houdini] Creating app menu items…
2022-02-08 17:14:49,349 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: ShotGrid Panel…
2022-02-08 17:14:49,350 [62427 DEBUG sgtk.env.project.tk-houdini] Creating tool: File Save…
2022-02-08 17:14:49,351 [62427 DEBUG sgtk.env.project.tk-houdini] Assigning tools to shelf <hou.Shelf ‘ShotGrid’>…
2022-02-08 17:14:49,352 [62427 DEBUG sgtk.env.project.tk-houdini] …done!
2022-02-08 17:14:49,353 [62427 DEBUG sgtk.env.project.tk-houdini] set utf-8 codec for widget text
This is part 2 of 2 of tk-houdini.log.
2022-02-08 17:14:49,353 [62427 DEBUG sgtk.env.project.tk-houdini] Starting metrics dispatcher…
2022-02-08 17:14:49,353 [62427 DEBUG sgtk.core.util.shotgun.connection] Creating SG connection from <SessionUser @USERNAME@@@STUDIODNS@ @ https://@SITENAME@.shotgunstudio.com>…
2022-02-08 17:14:49,353 [62427 DEBUG sgtk.env.project.tk-houdini] Added worker thread: <MetricsDispatchWorkerThread(Thread-2, started daemon 123145637421056)>
2022-02-08 17:14:49,354 [62427 DEBUG sgtk.stopwatch.tank.util.shotgun.connection] create_sg_connection: 0.000340s
2022-02-08 17:14:49,354 [62427 DEBUG sgtk.env.project.tk-houdini] Metrics dispatcher started.
2022-02-08 17:14:49,354 [62427 DEBUG sgtk.env.project.tk-houdini] Init complete: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>
2022-02-08 17:14:59,239 [62427 DEBUG sgtk.env.project.tk-houdini] Grouped registered commands.
2022-02-08 17:14:59,240 [62427 DEBUG sgtk.env.project.tk-houdini] Collected context commands for dynamic menu.
2022-02-08 17:14:59,241 [62427 DEBUG sgtk.env.project.tk-houdini] Collected app commands for dynamic menu.
2022-02-08 17:15:20,570 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] Synchronizing remote path cache…
2022-02-08 17:15:20,571 [62427 DEBUG sgtk.core.path_cache] Path cache sync tracking marker in local sqlite db: 695124
2022-02-08 17:15:20,571 [62427 DEBUG sgtk.core.path_cache] Fetching create/delete folder event log entries >= id 695124 for project {‘type’: ‘Project’, ‘id’: 123}…
2022-02-08 17:15:20,650 [62427 DEBUG sgtk.core.path_cache] Got 1 event log entries
2022-02-08 17:15:20,650 [62427 DEBUG sgtk.core.path_cache] Event log contains 1 creations and 0 deletions
2022-02-08 17:15:20,650 [62427 DEBUG sgtk.core.path_cache] Path cache syncing not necessary - local folders already up to date!
2022-02-08 17:15:20,650 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] Path cache up to date!
2022-02-08 17:15:20,665 [62427 DEBUG sgtk.env.project.tk-houdini] Found top level widget <PySide2.QtWidgets.QWidget object at 0x15e903a00> for dialog parenting
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel]
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Model Reset for
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Entity type: Task
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Filters: [[‘project’, ‘is’, {‘type’: ‘Project’, ‘id’: 123, ‘name’: ‘@PROJECTNAME@’}], [‘task_assignees’, ‘is’, {‘type’: ‘HumanUser’, ‘id’: 88, ‘name’: ‘Marcia Goetsch’}]]
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Hierarchy: [‘content’]
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Fields: [‘image’, ‘entity’, ‘content’]
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Order:
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Columns:
2022-02-08 17:15:20,688 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Editable Columns:
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Filter Presets: None
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Loading data from cache file into memory…
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Loading from disk: /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Task/7802b829d80e7ed46cc7d7612dc0287b/09c286ec15ccf208179a2d7baa234e4e.27
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] No cache found on disk. Starting from empty data store.
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Cache load complete: <ShotgunFindDataHandler@/Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Task/7802b829d80e7ed46cc7d7612dc0287b/09c286ec15ccf208179a2d7baa234e4e.27 (0 items)>
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] load_cache: 0.000208s
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] First population pass: Calling _load_external_data()
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] External data population done.
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [MyTasksModel] Creating model nodes for top level of data tree…
2022-02-08 17:15:20,689 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Creating child nodes for parent uid None
2022-02-08 17:15:20,690 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] generate_child_nodes: 0.000489s
2022-02-08 17:15:20,690 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Task Manager: Started new background worker thread (num threads=1)
2022-02-08 17:15:20,690 [62427 DEBUG sgtk.core.util.shotgun.connection] Creating SG connection from <SessionUser @USERNAME@@@STUDIODNS@ @ https://@SITENAME@.shotgunstudio.com>…
2022-02-08 17:15:20,691 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Initialized settings manager for ‘tk-multi-workfiles2’
2022-02-08 17:15:20,691 [62427 DEBUG sgtk.stopwatch.tank.util.shotgun.connection] create_sg_connection: 0.000467s
2022-02-08 17:15:20,691 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] User Settings Manager: Retrieving step_filters
2022-02-08 17:15:20,695 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel]
2022-02-08 17:15:20,695 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Model Reset for
2022-02-08 17:15:20,695 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Entity type: Asset
2022-02-08 17:15:20,695 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filters: [[‘project’, ‘is’, {‘type’: ‘Project’, ‘id’: 123, ‘name’: ‘@PROJECTNAME@’}]]
2022-02-08 17:15:20,695 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Hierarchy: [‘sg_asset_type’, ‘code’]
2022-02-08 17:15:20,695 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Fields:
2022-02-08 17:15:20,695 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Order:
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Columns:
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Editable Columns:
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filter Presets: None
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Loading data from cache file into memory…
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Loading from disk: /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Asset/2c78acfb14e9ac368a7d6c636e170673/e3a2bf02c2152f114fadfaca795f6ab8.27
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] No cache found on disk. Starting from empty data store.
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Cache load complete: <ShotgunFindDataHandler@/Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Asset/2c78acfb14e9ac368a7d6c636e170673/e3a2bf02c2152f114fadfaca795f6ab8.27 (0 items)>
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] load_cache: 0.000204s
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] First population pass: Calling _load_external_data()
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] External data population done.
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Creating model nodes for top level of data tree…
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Creating child nodes for parent uid None
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] generate_child_nodes: 0.000056s
2022-02-08 17:15:20,696 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Unloading in-memory cache for <ShotgunFindDataHandler@/Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Asset/2c78acfb14e9ac368a7d6c636e170673/e3a2bf02c2152f114fadfaca795f6ab8.27 (0 items)>
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Model Reset for
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Entity type: Asset
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filters: [[‘project’, ‘is’, {‘type’: ‘Project’, ‘id’: 123, ‘name’: ‘@PROJECTNAME@’}]]
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Hierarchy: [‘sg_asset_type’, ‘code’]
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Fields:
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Order:
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Columns:
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Editable Columns:
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filter Presets: None
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Loading data from cache file into memory…
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Loading from disk: /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Asset/2c78acfb14e9ac368a7d6c636e170673/e3a2bf02c2152f114fadfaca795f6ab8.27
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] No cache found on disk. Starting from empty data store.
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Cache load complete: <ShotgunFindDataHandler@/Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Asset/2c78acfb14e9ac368a7d6c636e170673/e3a2bf02c2152f114fadfaca795f6ab8.27 (0 items)>
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] load_cache: 0.000165s
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] First population pass: Calling _load_external_data()
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] External data population done.
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Creating model nodes for top level of data tree…
2022-02-08 17:15:20,697 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Creating child nodes for parent uid None
2022-02-08 17:15:20,698 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] generate_child_nodes: 0.000059s
2022-02-08 17:15:20,698 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Task Manager: Started new background worker thread (num threads=2)
2022-02-08 17:15:20,698 [62427 DEBUG sgtk.core.util.shotgun.connection] Creating SG connection from <SessionUser @USERNAME@@@STUDIODNS@ @ https://@SITENAME@.shotgunstudio.com>…
2022-02-08 17:15:20,698 [62427 DEBUG sgtk.stopwatch.tank.util.shotgun.connection] create_sg_connection: 0.000332s
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel]
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Model Reset for
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Entity type: Shot
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filters: [[‘project’, ‘is’, {‘type’: ‘Project’, ‘id’: 123, ‘name’: ‘@PROJECTNAME@’}]]
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Hierarchy: [‘sg_sequence’, ‘code’]
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Fields:
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Order:
2022-02-08 17:15:20,699 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Columns:
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Editable Columns:
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filter Presets: None
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Loading data from cache file into memory…
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Loading from disk: /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Shot/98105b718f489c22764117ce7e057191/e3a2bf02c2152f114fadfaca795f6ab8.27
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] No cache found on disk. Starting from empty data store.
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Cache load complete: <ShotgunFindDataHandler@/Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Shot/98105b718f489c22764117ce7e057191/e3a2bf02c2152f114fadfaca795f6ab8.27 (0 items)>
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] load_cache: 0.000185s
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] First population pass: Calling _load_external_data()
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] External data population done.
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Creating model nodes for top level of data tree…
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Creating child nodes for parent uid None
2022-02-08 17:15:20,700 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] generate_child_nodes: 0.000078s
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Unloading in-memory cache for <ShotgunFindDataHandler@/Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Shot/98105b718f489c22764117ce7e057191/e3a2bf02c2152f114fadfaca795f6ab8.27 (0 items)>
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel]
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Model Reset for
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Entity type: Shot
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filters: [[‘project’, ‘is’, {‘type’: ‘Project’, ‘id’: 123, ‘name’: ‘@PROJECTNAME@’}]]
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Hierarchy: [‘sg_sequence’, ‘code’]
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Fields:
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Order:
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Columns:
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Editable Columns:
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Filter Presets: None
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Loading data from cache file into memory…
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Loading from disk: /Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Shot/98105b718f489c22764117ce7e057191/e3a2bf02c2152f114fadfaca795f6ab8.27
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] No cache found on disk. Starting from empty data store.
2022-02-08 17:15:20,701 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Cache load complete: <ShotgunFindDataHandler@/Users/@USERNAME@/Library/Caches/Shotgun/@SITENAME@/site/fw-shotgunutils/sg/Shot/98105b718f489c22764117ce7e057191/e3a2bf02c2152f114fadfaca795f6ab8.27 (0 items)>
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] load_cache: 0.000273s
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] First population pass: Calling _load_external_data()
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] External data population done.
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunDeferredEntityModel] Creating model nodes for top level of data tree…
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] [ShotgunFindDataHandler] Creating child nodes for parent uid None
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.stopwatch.tkimpc939284a7772401d815c61f4e2487b58.shotgun_model.data_handler] generate_child_nodes: 0.000058s
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Task Manager: Started new background worker thread (num threads=3)
2022-02-08 17:15:20,702 [62427 DEBUG sgtk.core.util.shotgun.connection] Creating SG connection from <SessionUser @USERNAME@@@STUDIODNS@ @ https://@SITENAME@.shotgunstudio.com>…
2022-02-08 17:15:20,703 [62427 DEBUG sgtk.stopwatch.tank.util.shotgun.connection] create_sg_connection: 0.001036s
2022-02-08 17:15:20,908 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] SG API find start: (‘Step’, , [‘code’, ‘entity_type’, ‘color’]) {‘order’: [{‘field_name’: ‘code’, ‘direction’: ‘asc’}]}
2022-02-08 17:15:20,998 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] SG API find end
2022-02-08 17:15:20,998 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Initialized settings manager for ‘tk-multi-workfiles2’
2022-02-08 17:15:20,998 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] User Settings Manager: Retrieving step_filters
2022-02-08 17:15:21,057 [62427 DEBUG sgtk.env.project.tk-houdini.tk-multi-workfiles2] Retrieving current scene path…
2022-02-08 17:15:21,057 [62427 DEBUG sgtk.core.platform.bundle] <Sgtk App 0x15e8d7d10: tk-multi-workfiles2, engine: <Sgtk Engine 0x16f81cb50: tk-houdini, env: project>>: Resolved hook expression (associated with setting ‘hook_scene_operation’): ‘{self}/scene_operation_tk-houdini.py’ → [’/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-workfiles2/v0.13.1/hooks/scene_operation_tk-houdini.py’]
2022-02-08 17:15:21,063 [62427 DEBUG sgtk.env.project.tk-houdini.tk-framework-shotgunutils] Task Manager: Started new background worker thread (num threads=4)
2022-02-08 17:15:21,064 [62427 DEBUG sgtk.env.project.tk-houdini] Detected std style sheet file ‘/Volumes/@VOLUMENAME@/Shotgun/configs/@PROJECTNAME@/install/app_store/tk-multi-workfiles2/v0.13.1/style.qss’ - applying to widget <tank.platform.qt.tankqdialog.FileSaveForm_TkWidgetWrapper object at 0x161723190>
Ok there is no visible error here.
What I usually do in this case is start houdini in shotgrid from the terminal:
path-to-project/tank houdini_fx_18.5.596
(the exact name of the command depends on the names of your Software entities)
Then the error should be visible in the terminal when you reproduce the crash.
I did that and it shows no errors. Is there a debug mode to increase verboseness? I am running Shotgun Desktop with Python 2. But Houdini seems to be running with Python 3. Is that a problem?
Edit: I switched SG Desktop to Python 3, with no improvement.
Upgrading Houdini to version 19.0.498 resolved my issue.
