Houdini SGTK App crash on close
I everyone, I’m trying to use SGTK apps with Houdini 18.0.460, and each time I have an opened App (like tk-multi-workfiles2 or tk-multi-publish2) and I close Houdini, I get a crash.
My log is
Crash report from tlegranche; Houdini Core Version 18.0.460 [linux-x86_64-gcc6.3]
Uptime 91 seconds
Wed May 27 16:00:17 2020
Caught signal 6
Traceback from 1329 ThreadId=0x7fc9fc10ad40
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
_L_unlock_13 <libpthread.so.0>
__GI_raise <libc.so.6>
__GI_abort <libc.so.6>
QMessageLogger::fatal(char const*, ...) const <libQt5Core.so.5>
QThread::~QThread() <libQt5Core.so.5>
QThreadWrapper::~QThreadWrapper() <QtCore.so>
QObjectPrivate::deleteChildren() <libQt5Core.so.5>
QObject::~QObject() <libQt5Core.so.5>
QObjectWrapper::~QObjectWrapper() <QtCore.so>
QWidget::~QWidget() <libQt5Widgets.so.5>
QWidgetWrapper::~QWidgetWrapper() <QtWidgets.so>
QStackedWidgetWrapper::~QStackedWidgetWrapper() <QtWidgets.so>
QDialogWrapper::~QDialogWrapper() <QtWidgets.so>
re_QWindowWidget::~re_QWindowWidget() <libHoudiniUI.so>
QObject::event(QEvent*) <libQt5Core.so.5>
QWidget::event(QEvent*) <libQt5Widgets.so.5>
QApplicationPrivate::notify_helper(QObject*, QEvent*) <libQt5Widgets.so.5>
QApplication::notify(QObject*, QEvent*) <libQt5Widgets.so.5>
QCoreApplication::notifyInternal2(QObject*, QEvent*) <libQt5Core.so.5>
QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) <libQt5Core.so.5>
ap_shutDownQtApp(void*) <libHoudiniUI.so>
doExitCallbacks() <libHoudiniUT.so>
UT_Exit::doExit(int, bool) <libHoudiniUT.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
main <houdinicore-bin>
Any idea on what happen here ?
Hi @tristanlg
I’m sorry you’re hitting issues, what versions of the following are you using?
  • tk-houdini
  • tk-core
  • tk-multi-workfiles2
  • tk-framework-shotgunutils
  • tk-framework-qtwidgets
Best
Phil
Hi @tristanlg
We’ve actually reproduced the issue on our side as well, and I’ve ticketed this up.
Thanks for reporting it, we’ll post back here once it is resolved.
Phil
Hi !
Thanks for your feedbacks @philip.scadding !
We’ll wait for a fix.
Tristan
Hi @philip.scadding, any news about this bug ? :slight_smile:
Hi @tristanlg,
It looks like this is still in our backlog to fix, we don’t currently have any updates for you sorry.
Looking the at the testing it seems it affects Houdini 18.0.407+, Would a current workaround to use an earlier build be an option for you?
-David
Hi @DavidMason and @philip.scadding,
We are using Houdini 18.5.696, and we are still facing the issue.
Any news?
I’m getting a crash on exit with an almost identical stacktrace using Houdini 19.0.589.
Was this ever fixed?
Many thanks,
John.
Hello folks, and sorry for the late response.
We investigated this and found a potential fix for this. We’re still testing it. I’ll get back to you with the results.
Cheers.
Hi @carlos-villavicencio
We are also experiencing crashes on exit. Any news on the potential fix ?
We are using Houdini 20.5.410 on Windows.
tk-core : v0.21.6
tk-houdini: v1.9.3
Hello @donat , sorry for the bad news but we haven’t found anything so far.
Some months ago I opened a couple of PR to test:
They worked until some point, but they didn’t fix it completely. Feel free to try them if you want. Let me know if you have some results to share.
Thanks, we will try the PR
