Tk-multi-breakdown2 houdini UI lockup
I have a project using:
tk-houdini v1.9.3
tk-multi-breakdown2 v0.4.2
tk-framework-qtwidgets_v2.x.x v2.12.4
rocky linux 8.9
While using the breakdown2 panel in houdini (20.0.724, 20.5.370), we encounter a behavior where the UI in houdini locks up when an item is selected in the breakdown2 panel. Only after deselecting that item is houdini UI interaction able to resume.
Has anyone else experienced this?
-Jake
We also have been getting a lockup using the breakdown in Houdini but not sure if it’s the same issue. Do you get ssl certificate errors when it tries to download the thumbnails? This is the error we are experiencing:
Error reported: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)>
Hi Brett,
We’ve been able to download thumbnails and I haven’t seen that particular SSL error. Unfortunately, sounds like a different issue.
Are you using tk-multi-breakdown2 v0.4.2?
-Jake
Hi Jake,
I just tried v0.4.2 and I was able to reproduce your lockup issue. It does appear to lock up Houdini after clicking on an item.
On a side note, I am still getting ssl errors even with the latest version. Not sure why.
-Brett
Thanks for confirming it’s an issue for you too.
try setting the environment variable SHOTGUN_API_CACERTS and point it to the cacerts text file in the shotgun_api3 (grab the latest).
Some background to how this works:
Hi Ricardo,
Unfortunately I’ve tried everything in that document and I still get the ssl errors. Strange that I’m only seeing the errors inside Houdini and not the other apps like Nuke.
Screenshot shows attempt with shotgun-api3 3.6.2 cert file.
-Brett
Not sure, would be worth making a ticket to Autodesk for this.
