Hi Shotgun-team,
We are completing the process of migration.
Just have a small question about shotgrid desktop.
Is there any extra steps to follow for that.
or it will happen automatically after migration of all the account is done.
Hi Shotgun-team,
Hi @a.despande
The default behaviour of the SG Desktop is to use the simple login dialog while the site is still in the migration process. Once the site fully switches to Autodesk Identity, the Web login will be used.
With the latest versions of tk-framework-desktopstartup (which you need to connect to your site at least once for it to be downloaded, if your config is not frozen) you can tell the SG Desktop to use the Web login by setting the Environment Variable SGTK_DESKTOP_SUPPORT_WEB_LOGIN_TRUE to a any value.
Hoping this helps,
-Patrick
