I have met a problem when I save the file in Shotgrid Desktop. So the shotgrid Desktop showed that it doesn’t match any defined Local Storage, but I already set path correctly. I don’t know why this is happened?
This attachment that snapped the screen.
Thank you
There are a couple of places where you define your local storages - in Site Preferences in Shotgun, and if you have a config override - in the roots.yml file.
Check out
https://help.autodesk.com/view/SGSUB/ENU/?guid=SG_Administrator_ar_data_management_ar_linking_local_files_html
Thank you so much, it help me a lot!
