Sgtk/tk-core module GUI not working with python 3.11
I have tools made in python3.8 which are using Flow Production Tracking core platform, v0.21.8 — tk-core v0.21.8 documentation module. This module is used for authentication and shows GUI when calling its get_user() function of class
*class* sgtk.authentication.ShotgunAuthenticator(*defaults_manager=None* )
However, when upgrading tools to python 3.11, the same function does not open GUI authentication but opens up in terminal. I want to know is there any other autodesk library I should be using for authentication in python 3.11 or there is something I am missing in this library that it is not working with python 3.11?. Any help would be appreciated.
I am tried using sgtk==0.21.7 and sgtk==0.21.8 for python 3.11.
Hi @Manibha , starting with Python version 3.11, PySide2 is not supported anymore and you need to switch/install PySide6.
That’s probably why the UI authentication does not show up.
I hope this helps.
Thankyou for you response @Julien-L , I figured out the issue.
The issue was with sgtk library which works with PySide6 & python 3.11 but not with PyQt6 & Python 3.11 . I forgot to add the libraries in the question.
