Problems to authenticate using tk-core Authenticator class
Hi guys,
Last week we migrated to the new Autodesk authentication and on the website, all is working fine but, in our pipeline, we’re using a custom DCC login, and that stopped working.
I updated to the current tk-core version (0.20.3), and we’re using the following lines to create our user:
import sgtk
authenticator  = sgtk.authentication.ShotgunAuthenticator()
But I got this error:
What is this “personal access token” that this authenticator is expecting?
Now our website log-in is by Autodesk so, how to authenticate using this web information?
Thank you,
Gabriel
I’ve debugged this script and I realized the Maya 2018 doesn’t have the Qt Web Modules to run the authentication online.
Anyway, if I try to authenticate it using the shotgun_api3.Shotgun class, I got the same error:
Have someone any idea?
Thank you very much,
Gabriel
Hi @gabrielv
The documentation for the Personal Access Token is here : Help
Once the PAT is associated to your user in ShotGrid, you will be able to use your your old username and password (or whatever you set your legacy login / passphrase in ShotGrid user settings) to log in.
Hoping this helps,
-Patrick
