Fail to authenticate with username/password in Python Shotgun API
I am working on 30 Days Trial site to evaluate that I can work with the Python API or not. I can authenticate with script key. However, when I use simple username (email) and password, I always get Can’t authenticate user.
I am not sure that did I set something wrong. Below is the command I used.
 sg = sgApi.Shotgun('my-trial-site-url', login='my-email', password='my-password')
Hi @nathanhunt
You do not give the output or mention the error message that you are getting…
Have you configured your Personal Access Token and set your legacy passphrase ?
The credentials you need to use for API-based authentication are NOT your Autodesk Identity username and password. Autodesk Identity authentication can only happen in a web browser.
You will need to use your ShotGrid login and passphrase.
Relevant info: Help
Hoping this helps,
-Patrick
