I want to take advantage of existing open rv instance to relaunch the new mov when user selects Play in rv from the shotgun in browser.
so if I use
rv rvlink:// -reuse 1 <path_to_mov> .
it does not work on linux for me.
I have tried it , rv opens with unable to decode error in rv console .
Am I doing something wrong ?
Hi @supercool,
The baked path is hex encoded. In python it is pretty easy to build this like this:
>>> print "rvlink://baked/%s" % "-reuse 1 path_to_mov".encode('hex')
rvlink://baked/2d7265757365203120706174685f746f5f6d6f76
When launching in RV, you can see the output of it decoding the baked url:
INFO: received URL 'rvlink://baked/2d7265757365203120706174685f746f5f6d6f76'
INFO: decoded URL 'rvlink://-reuse 1 path_to_mov'
Alternatively, you can use RV’s -bakeURL argument to produce one from command-line arguments:
Michaels-MacBook-Pro:~ kesslem$ /Applications/RV.app/Contents/MacOS/RV -reuse path_to_url -bakeURL
INFO: command line for baking ' -reuse path_to_url'
Baked URL: rvlink://baked/202d726575736520706174685f746f5f75726c
-Kessler
Hi @supercool,
That’s the URL that is generated for the Shotgun integration to open a version in RV (thanks omitting your actual server url)
Essentially it is calling the Mu commands to start up a new session with that version.
