RVIO -init uncatchable exception (gotta catch them all!)
I’m trying to prototype a custom init script for rvio and I’m running into an uncatchable exception on any add/modify source coummands.
Even with -debug mu I’m getting no useful output. Can I get a developer with a debug build to determine if this is an exception outside of Mu, and is there a workaround?
Here’s the minimal script:
use commands;
print("Beginning of custom mu init.\n");
try
	commands.setSourceMedia(src, ["solid,red=1.0,green=0.0,blue=0.0,start=1,end=100.movieproc"]);
catch (exception exc)
	let s = string(exc);
	print(s);
print("End of custom mu init.\n");
Run the test with:
rvio -init <pathToScript> solid.movieproc -o ./test.mov -debug mu
I presently get:
...(version and copyright notice)
INFO: solid.movieproc
INFO: setting view to single Source
ERROR: uncaught exception
-Kessler
Hello Kessler !
Yes sure : I need to take are of something first, but I promise to investigate this in a debug build over the week-end and report back to you what I find.
Bernie
Hello @Michael.Kessler,
I was able to reproduce this issue and it has to do with the way you were passing the array of string parameters : in this form the Mu parser is not able to digest it which leads to an exception.
I was able to make your script work by passing the new_media parameter differently:
This works:
let src = "sourceGroup000000_source";
commands.setSourceMedia(src, string[] {"solid,red=0.0,green=1.0,blue=0.0,start=1,end=100.movieproc"});
And this also works:
string[] new_media;
new_media.push_back("solid,red=0.0,green=1.0,blue=0.0,start=1,end=100.movieproc");
commands.setSourceMedia(src, new_media);
I hope this helps.
Cheers !
Bernie
