I am working on shotgrid RV player, where I am trying to import two different .mov files and overlapp them and then export the resultant .mov file.
I am providing more context here below:
Script which I am using is as follows :
import subprocess
def open_shotgun_rv_player(file_path_1, file_path_2, export_path):
rv_executable = 'C:/Program Files/ShotGrid/RV-2022.3.1/bin/rv.exe' # Replace with the actual path to the 'rv' executable
# command = [rv_executable,'-help']
command = [rv_executable, file_path_1,file_path_2,'view %s'%('add')] # # Add the export option to the command
process = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
stdout, stderr = process.communicate()
stdout_lines = stdout.decode().splitlines()
stderr_lines = stderr.decode().splitlines()
print("Standard error:")
for line in stderr_lines:
print(line)
file_path_1 = 'C:/...../dummy_0200_layout_v01.mov'
file_path_2 = 'C:/..../dummy_0300_animatic_v05.mov'
export_path = 'Q:/..../export.mov'
I am getting this following error :
ERROR: Open of 'view add' failed: unsupported media type.
Now to get idea from the software perspective I am trying to do the following operations.
I haven’t added the export path yet as I tried few things but I was getting errors well. So any help on these issues would be really helpful.
Thanks & Regrads
