Is there a way to group assets by specific episodic sequences they are used in?
Right now when I group them on the asset page, it includes all the sequences from all the episodes. Is there a way to filter the groups perhaps?
Or any other alternate method would be great
Set up advanced grouping?
First by Episode, then by Sequence?
No luck - it takes all the sequences from other episodes as well
You will need to add a filter for the specific episode(s) you want to include or not-include.
Grouping on pages will always include all values in the field you’re grouping with as well as ones that are blank.
If you don’t have a direct episode field to filter with, you will need to use the linked fields at the bottom of the filter list. I’m guessing it will be under the sequence linked fields in your case.
