I want to change the default setting of the rv
If you double-click and open the movie file that connects rv, it is Color - Rec709, but View - sRGB. So I want to change the default setting value of View to Rec709, but I don’t know how Do you happen to know how to change View defaults?
Hi @samyang
Use below script for rec709
“rv.exe” -rec709
rv.exe → give rv location where it is installed in your machine
