Open RV in Rec709
My apologies for what is probably a very simple question. When in Shotgrid and using Play in RV to review shots, how do I get RV to default to opening in Rec709 and not sRGB?
Any direction or links to articles would be appreciated.
Many thanks,
Blake
Hi @Fabes,
Do you mean the view or the linearization for rec709? For view, check out display profiles, otherwise for linearization check out source setup plugins.
If you want a particular extension to default to rec709, theres an environment variable you can set to make an override transfer, see this doc:
Hi @Fabes
Use below script for rec709
“rv.exe” -rec709
rv.exe → give rv location where it is installed in your machine
