How do I set a view display profile as a default?
I would like to be able to set View -> Linear to Display Correction to always reference the same preference on startup.
For example, I want No Conversion to be default correction. How do I achieve this?
You can go to:
RV → View → No Correction
[![enter image description here][1]][1]
Then you can set it as default in preferences:
RV → Preferences → Video tab → Output Device → use Module Profile (pick the profile you just created)
[![enter image description here][2]][2]
[1]: //cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/shotgunsoftware/original/2X/0/07e1341ac9c3b7b819ef38da299789f7a93e1843.png [2]: //cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/shotgunsoftware/original/2X/8/8568ac1623f88f067d5366454f53fe5547710582.png note that this is hardware specific to your current display. If you change your hardware, you will need a new profile for the color transform to be correct.
