How to make the value of sg_asset_type take effect only in the current project
Hi.
When I set the value of the field “sg_asset_type”, I found that the value will take effect on all projects. But I don’t want this effect, I want my value to be valid only for the current project.
When I set other or custom fields to take effect only in the current project, but sg_asset_type is an exception, is this a bug?
Hi @heylenz, welcome to the community! :wave:
You’ve discovered a limitation with Shotgun. While statuses are configurable per project, the values in list fields are not, currently. You’d need to create another list field type to track another set of data. I recommend submitting your idea to our public roadmap which is delivered straight to our Product Team:
Shayna
thanks, shaynad! I will create another field!
