When I load up a Playlist of Versions in RV, we sometimes need to desaturate all the clips for review purposes. How can I do that for the entire timeline/all source inputs?
One quick, built-in way, is to swap to your layout view which should have all your sources that you’ve loaded, set your saturation to 0 (with shift+S, 0, ) and then go back to your sequence.
This is what changing from Default Sequence…
To Default Layout looks like:
