In our studio, some users get Framework configuration Error during Shotgun Desktop’s initial launch after the software installation.
The launcher’s loading fails somewhere after the users type their username & password and before UI appears.
So far reinstalling the software fixes this, but I’m wondering what is causing this issue.
Below is tk-desktop.log from one of the users:
Thanks, Yu
2020-07-07 11:57:35,673 [4540 ERROR sgtk.ext.shotgun_desktop.startup] Fatal error, user will be logged out.
File “C:\Users{username}\AppData\Roaming\Shotgun\desktop\install\app_store\tk-framework-desktopstartup\v1.10.6\python\shotgun_desktop\startup.py”, line 726, in main
settings
File “C:\Users{username}\AppData\Roaming\Shotgun\desktop\install\app_store\tk-framework-desktopstartup\v1.10.6\python\shotgun_desktop\startup.py”, line 338, in __launch_app
engine = __start_engine_in_zero_config(app, app_bootstrap, splash, user)
File “C:\Users{username}\AppData\Roaming\Shotgun\desktop\install\app_store\tk-framework-desktopstartup\v1.10.6\python\shotgun_desktop\startup.py”, line 456, in __start_engine_in_zero_config
return mgr.bootstrap_engine(“tk-desktop”)
File “C:\Users{username}\AppData\Roaming\Shotgun\desktop\install\app_store\tk-framework-desktopstartup\v1.10.6\python\tk-core\python\tank\bootstrap\manager.py”, line 492, in bootstrap_engine
engine = self._start_engine(tk, engine_name, entity)
File “C:\Users{username}\AppData\Roaming\Shotgun\desktop\install\app_store\tk-framework-desktopstartup\v1.10.6\python\tk-core\python\tank\bootstrap\manager.py”, line 1201, in _start_engine
engine = tank.platform.start_engine(engine_name, tk, ctx)
File “C:\Users{username}\AppData\Roaming\Shotgun{studioname}\sitec40.basic.desktop\cfg\install\core\python\tank\platform\engine.py”, line 2809, in start_engine
return _start_engine(engine_name, tk, None, context)
File “C:\Users{username}\AppData\Roaming\Shotgun{studioname}\sitec40.basic.desktop\cfg\install\core\python\tank\platform\engine.py”, line 2956, in _start_engine
engine = class_obj(tk, new_context, engine_name, env)
File “C:\Users{username}\AppData\Roaming\Shotgun\bundle_cache\sg{studioname}\v16026\resources\integration\tk-desktop\engine.py”, line 23, in init
Engine.init(self, tk, *args, **kwargs)
File “C:\Users{username}\AppData\Roaming\Shotgun{studioname}\sitec40.basic.desktop\cfg\install\core\python\tank\platform\engine.py”, line 149, in init
setup_frameworks(self, self, self.__env, descriptor)
File “C:\Users{username}\AppData\Roaming\Shotgun{studioname}\sitec40.basic.desktop\cfg\install\core\python\tank\platform\framework.py”, line 241, in setup_frameworks
fw_obj = load_framework(engine_obj, env, fw_inst_name)
File “C:\Users{username}\AppData\Roaming\Shotgun{studioname}\sitec40.basic.desktop\cfg\install\core\python\tank\platform\framework.py”, line 309, in load_framework
setup_frameworks(engine_obj, fw, env, descriptor)
File “C:\Users{username}\AppData\Roaming\Shotgun{studioname}\sitec40.basic.desktop\cfg\install\core\python\tank\platform\framework.py”, line 291, in load_framework
raise TankError(“Framework configuration Error for %s: %s” % (fw_instance_name, e))
TankError: Framework configuration Error for tk-framework-shotgunutils_v5.x.x: Cannot load metadata file ‘C:\Program Files\Shotgun\Resources\Python\bundle_cache\app_store\tk-framework-shotgunutils\v5.6.1\info.yml’. Error: unacceptable character #x0000: special characters are not allowed
in “C:\Program Files\Shotgun\Resources\Python\bundle_cache\app_store\tk-framework-shotgunutils\v5.6.1\info.yml”, position 0
