Exporting task link
I am trying to export a list of tasks to excel including shotgun links to open those tasks but I can’t seem to figure out a way to do it. Any suggestions?
Cheers
Rohit
YES! We use the URL Template field to copy links out of Shotgun into Slack & other stuff so folks can go directly to versions & notes, so I’m sure you can use the same trick on Tasks.
Set up a field on Tasks that is a URL Template, and export the information to Excel that way. The field set up would look like this:
https://YOURSTUDIONAME.shotgunstudio.com/detail/Task/{id}
And then in Excel it looks like this:
https://YOURSTUDIONAME.shotgunstudio.com/detail/Task/12345
https://YOURSTUDIONAME.shotgunstudio.com/detail/Task/12346
https://YOURSTUDIONAME.shotgunstudio.com/detail/Task/12347
I don’t know enough about Excel to tell you how to make that text into hyperlinks but I’m sure someone out in the world wide web has posted a how-to for that part.
Thanks Jessica, that worked!
