Hi.
The RV integration to Shotgrid is great!
I have a workflow question for comparing versions though. In the details pane you can right click on a version and select ‘Swap into sequence’ to view in RV another version of the same entity. I’m using this constantly to compare a given version to the plate for example.
Is there a hotkey to Swap versions?
I found that shift+up/down arrow will cycle through versions, and that alt+shift+up/down will swap to the first version.
But I cant find a way to compare two selected version with a hotkey, just like the same function as right click->‘Swap Into sequence’.
Does anybody know? Or does anybody have another way to compare 2 selected versions in the detail pane?
Thanks ![]()
