Client review site versions
I wonder if there is a way in the Client review site to combine all related versions of the same shot, because right now there are all listed one version after another, not very friendly when the client needs to compare versions.
Thanks in advance :slight_smile:
Hi Osama,
Thanks for writing in, we’ll be happy to help out here.
This is an excellent suggestion here, we’ve certainly heard from other clients they’d like an easy way to be able to compare previous versions via the Client Review Site. Unfortunately, this isn’t currently possible at the moment, as the client review doesn’t distinguish between versions that are from the same shot in a playlist.
We’d be super curious to hear your use-case here, as it sounds like your workflow involves sharing multiple versions of the same shot via the client review site, are they perhaps choosing from a select number of variations?
It would also be awesome if you could add this use-case to our public roadmap
Apologies we don’t have a better solution as of right now, but if you have any further questions don’t hesitate to give us a shout.
Andrew
