8.63 Release Notes
Release date: May 21, 2024 ET
We released the following updates since 8.62:
Improvements
Subscription Manager
  • You can view and manage your team subscription details with the Subscription Manager, available in the Apps menu under ADMIN TOOLS. Use the Subscription Manager to view what subscription type is assigned to each user, and change this assignment as required. Learn more about the Subscription Manager here.
  • Access admin functionality permission needs to be enabled for users to update subscription information. If this permission is not enabled for users, they will be restricted to a read-only view.
Integration - Licensing
  • For sites on non-tflex subscription: Usage licence are now automatically renewed. The idleness modal dialog that appears every 24 hours should no longer be visible. [SG-34457]
Bug fixes:
Overlay Player
  • Fixed a regression where all the cuts would be played in the overlay player regardless of the mini cuts defined. [SG-35131]
Page
  • Fixed a visual issue, where in some cases trial days left would be different on global navigation bar and on the trial banner. [SG-34486]
Entity Detail
  • Reducing the payload returned by cross-project assets. [SG-33313]
Review Notes App
  • Fixed an issue where not all layout changes were correctly saved when saving a new layout in the review notes app. [SG-35261]
  • Fixes an issue where the layout would not be fully loaded initially when opening the review notes app. [SG-34902]
Media App
  • Fixed an issue where the user couldn’t drag and drop versions into Playlist in Media App. [SG-35107]
Also in this version:
Bug fix
Scripts
  • Fixed copying and generating Script key issue. [SG-35109]
v8.63.0.4018 (Tuesday May 21, 2024 ET)
Bug fix
Entity Importer
  • Fixed an issue where importing data with date fields displayed as “dd/mm/yy” format would produce an error on the preview step. [SG-34765]
v8.63.0.4019 (Wednesday May 22, 2024 ET)
Bug fix
Filter Panel
  • Fixed an issue where in some cases an “Oops” error happened when filtering page data by a number field that was segmented by sliders. [SG-35029]
v8.63.0.4040 (Monday May 27, 2024 ET)
Bug fix
Page Creation Form
  • Fixed an issue where a pre-filled URL creation form would not work with entity or multi-entity field values. [SG-34490]
v8.63.0.4053 (Wednesday May 29, 2024 ET)
Bug fix
Help
  • Updated “Visit Our Help Site” user menu item link. [SG-35110]
v8.63.0.4059 (Thursday May 30, 2024 ET)
Bug fixes
Account
  • Fixed a link in a 2FA error message. [SG-35303]
Permissions
  • Fixed an issue where changing a field’s user permissions in the field configuration would result in an “Oops” error. [SG-34878]
v8.63.0.4094 (Wednesday June 5, 2024 ET)
Bug fix
Review Notes App
  • Fixed an issue where a layout would not fully load when opening the Review Notes App. [SG-34902] [SG-35319]
v8.63.0.4099 (Thursday June 6, 2024 ET)
Bug fixes
Email Notifications
  • Multiple inbox notification emails for a given entity will now group together as one conversation in an email client. [SG-33464]
    Note: When using both legacy and newer inbox notification emails, if the legacy emails are configured to have a different subject to the inbox notifications, they won’t be grouped in the same conversation thread. Instead, they will have a separate conversation thread.
  • For sites with non-tflex subscriptions, usage licenses are now automatically renewed and the idleness modal dialog that appeared every 24 hours is no longer be visible. [SG-34474]
