Release date: June 29, 2020
In this release we’ve focused on further refinements to the importer.
Improved support for date formats during import
When importing spreadsheet data that contains columns of dates, you can now specify the way the dates are formatted (which may be different to the format you have chosen in your site’s preferences).
Other changes
- Column mappings chosen during import will now be applied to future imports within the current project only. [SG-16611]
- Fixed an issue when toggling some pipeline steps visibility and then removing and adding other steps would cause an error. [SG-17506]
- Fix for synchronization in Task selection between Gantt and grid view. [SG-17707]
