8.69 Release Notes
Release date: November 19th, 2024 ET
We released the following updates since 8.68:
Bug fixes:
RV
  • Fixed an issue where j2c and j2k files could not be open in RV on Windows [SG-36544]
  • Fixed an issue where the transcoded audio files were no longer playable in the overlay player. Also added drag and drop support for audio .WAV files into FPTR. [SG-36442]
  • Fixed an issue where downloaded files could have incorrect name if uploaded via RV. [SG- 29511]
Entity Importer
  • Fixed an issue where importing a task with upstream dependency task would crash on the validation step. [SG- 29433]
ReviewAPP
  • Fixed an issue where some fields would be duplicated when resetting and reloading the application. [SG-36550]
  • Fixed an issue where in some cases the application could crash when attaching multiple files with the same name and deleting some of them. [SG-36326]
Filters
  • Fixed an issue where comparing between two dates that start and end on the same day would result in an error. [SG- 36767]
Status field
  • Fixed an issue where ASCII symbols could be allowed in the Short Code when creating a status on a Status field type [SG- 36360]
v8.69.0.5647 (December 3, 2024 ET)
Improvements
Permissions Page
  • Added description field on Permission Role Groups [SG-36589]
Bug fix
Linked Pipeline
  • Fixed an issue where Links Steps would be duplicated on Files page. [SG-36402]
Entity Filters
  • Fixed an issue where text would not be displayed on the Project filter. [SG- 36344]
  • Fixed an issue where text would not be displayed below “Show more..”. [SG- 36058]
v8.69.0.5667 (December 5, 2024 ET)
Improvements
Tasks Page → Gantt Chart
Display Task Dates in the Gantt Chart
Display any date field from the Task page in the Gantt chart.
display proposed date in the Gantt chart
In the Task page, you can now display any date field in the Gantt chart. The selected dates then appear as coloured dots in the chart.
To select the dates to display in the Gantt, open Gantt Display > Task Date Fields and select a date field.
Documentation
To learn more about how to show any task date in the Gantt chart, and the Task page in general, check out our documentation here.
