Release date: November 21, 2023 ET
We released the following updates since 8.56:
Improvement
We’ve added new graphs to monitor transcoder activity in the Site Activity Monitor
As an Admin, you now have more tools to monitor the activity of the ShotGrid transcoder. Learn more about these graphs here.
Bug fixes:
Filter Panel
- We’ve fixed a bug that was preventing the filter panel from correctly displaying filter groups that contained an invalid filter. This should now work as expected. [SG-33085]
Field (Administration)
- Fixed an issue which could occur when attaching a file to a multi-entity field of a file type. [SG32782]
Gantt
- Fixed an bug where an error would occur if viewing the Gantt chart, if there was a milestone task with no start date. [SG-31415]
Permissions
- Fixed an issue where in some cases after duplicating a permission role a user would have access to Configure Form Layout when there should be no access to the feature. [SG-30990]
Python API
- We’ve corrected a problem that was causing errors when making XML-RPC calls to the /api3 endpoint. You should no longer see the “Response from server does not contain valid XML” message. [SG-33296]
- We’ve resolved a technical glitch that previously allowed Task Template Tasks to be linked to a Project through the Python API. [SG-27640]
Task Templates
- Fixed an issue where the Entity’s Global page was not respecting the ‘Restrict to Project’ field in Task Templates. [SG-31859]
