Release date: July 21, 2020
In this release we’ve focused on further refinements to the importer.
Improvements to global imports
When importing spreadsheet data in the global context (outside of a particular project) that requires a project, you’ll now be prompted to associate the data with a specific project, or to provide a column in your spreadsheet with the correct project for each row.
Other changes
- It should no longer possible to map two or more columns to the same field during import. [SG-17572]
- Improved handling situations where date-like data is mapped to list or entity type fields. [SG-17897]
- When no theme has specifically been selected, Shotgun will fall back to the operating system theme. [SG-12632]
