Release date: June 5th, 2025 ET
We released the following updates since 8.74:
Improvements
Improved field search
It’s now easier to find the fields you need.
Simply start typing after opening the Fields menu, and the list will be filtered to show results matching your input - saving you time when working with entities with an extensive number of fields.
Tip:
Start typing as soon as you open the Fields menu to search it; you don’t have to first select Search and then type.
Widget Countdown improvements
he countdown widgets can now displays weeks and can use a Date Field from a project as the target date.
When you set up a countdown widget, you can now have it display the number of weeks remaining instead of the number of days.
Tip:
A tooltip displays the event date.
You can also select a Date Field from a project as the event date.
Note:
If you’re creating the widget for a specific project, only Date Fields from that project are shown.
Documentation
To learn more about the widgets, check out our documentation here.
Bug fix
Project Configurations
- Fixed an issue where changing a project navigation change would not be applied in some cases when changing a project configuration, if the project templated had been changed. [SG-38415]
Python API
- Fixed a Python API issue where querying data would return incorrect results if the entity operator included ‘name’ or ‘name_is’ containing special characters. [SG-38510]
Tasks
- Improved multiple row selection (holding the left mouse button) on the Grid and on the Gantt panel. Selection now happens instantaneously without any delays. [SG-38701]
Misc.
- Fixed an issue where editing long text caused the page to scroll and get stuck at the bottom, sometimes cropping the view and preventing users from navigating back.. [SG-38275]
