Release date: September 15th, 2025 ET
We released the following updates since 8.77:
Improvements
Pin Columns
You can now pin up to three columns in a grid.
Documentation
To learn more about layout options, check out our documentation here.
Bug fix
Calculated Fields
- Fixed an issue where calculated fields that display data in Days (or Hours), instead display the time in Minutes within the Gantt view. [SG-36303]
Query Fields
- Fixed an issue where, in some edge cases, a query field was not updated when a thumbnail was displayed and some rows were filtered out. [SG-39257]
Row Formatting Rules
Fixed an issue where rows were not correctly formatted when conditional formatting was applied based on the date fields. [SG-39841]
Fixed an issue where a tooltip would be still displayed after deleting a row formatting rule. [SG-39471]
Saved Filters
Fixed an issue where filtering a number field using non-numerical character would cause “error loading this widget” error. [SG-39188]
Fixed an issue where read / unread filters would not properly work on custom threaded entities 11 and 12. [SG-38339]
Importer
- Fixed an issue where existing tasks were not mapped to the imported data when importing tasks into a Task Template, what would result in a new tasks created instead of updating existing tasks [SG-39484]
User Permissions
- Fixed an issue where a non-admin user could delete a permission group on the People page via the row’s group ellipsis. [SG-39183]
Data Export
- Fixed an issue where HTML characters were present in the exported data headers for linked query fields. [SG-39710]
Notes
- Fixed an issue where creating a note from a task entity was stuck in a loop. [SG-38980]
