8.77 Release Notes
Release date: August 11th, 2025 ET
We released the following updates since 8.76:
Improvements
Preferences
  • Add custom duration for “User Session Expiry” preference. [SG-39061]
Bug fix
Email layouts
  • Fixed hint text on the Custom Threaded Entity Email Layout subject customization. [SG-39423]
Task page
  • Fixed an edge case issue where the Task page would hang with spinner when grouping by two fields and displaying a linked step thumbnail field. [SG-39340]
WebHooks
  • Fixed an issue where the WebHook filter “Older than” would not correctly work. [SG-37166]
Grid rows selection
  • Fixed an issue, where in some edge cases old rows selection would be still active after entities duplication . [SG-39174]
Status Icon
  • Fixed an issue where locked playlist would create an indent on status icon. [SG-38242]
v8.77.0.7049 (build f20ce14f96)
Improvements
Pin Columns
  • You can now pin up to three columns in a grid.
    Documentation
    To learn more about layout options, check out our documentation here.
Bug fix
Calculated Fields
  • Fixed an issue where calculated fields that display data in Days (or Hours), instead display the time in Minutes within the Gantt view. [SG-36303]
Query Fields
  • Fixed an issue where, in some edge cases, a query field was not updated when a thumbnail was displayed and some rows were filtered out. [SG-39257]
Row Formatting Rules
  • Fixed an issue where rows were not correctly formatted when conditional formatting was applied based on the date fields. [SG-39841]
  • Fixed an issue where a tooltip would be still displayed after deleting a row formatting rule. [SG-39471]
Saved Filters
  • Fixed an issue where filtering a number field using non-numerical character would cause “error loading this widget” error. [SG-39188]
  • Fixed an issue where read / unread filters would not properly work on custom threaded entities 11 and 12. [SG-38339]
Importer
  • Fixed an issue where existing tasks were not mapped to the imported data when importing tasks into a Task Template, what would result in a new tasks created instead of updating existing tasks [SG-39484]
User Permissions
  • Fixed an issue where a non-admin user could delete a permission group on the People page via the row’s group ellipsis. [SG-39183]
v8.77.0.7099 (build aaba57db76)
Bug fix
Data Export
  • Fixed an issue where HTML characters were present in the exported data headers for linked query fields. [SG-39710]
Notes
  • Fixed an issue where creating a note from a task entity was stuck in a loop. [SG-38980]
