Versions sorting in Client Review Site
Hi @tvanthuyne,
Welcome to the forums!
You can’t change the order of versions in a playlist in the Client Review Site’s interface. If you want to reorder versions in a playlist, you need to go to the Media page.
  1. You can navigate to the Media page using the Global navigation bar or the project’s navigation bar
  2. Select your project
  3. Select your shared playlist. You can search or browse for your playlist using the left sidebar.
  4. If your playlist is already shared and you want to change its order, you might need to unlock it.
  5. Next, you’ll want to sort your playlist by playlist order.
  6. Finally, you can drag and drop your versions in the playlist to put them in the desired order.
The Client Review will respect any order you set in the Media app when displaying versions to your clients.
Please note that you might want to lock your playlist again if you’ve had to unlock it to edit the version order.
I sure hope this help, Thomas.
